Open Loop Controller - MotionView
Assigns a MotionView signal to the driver output. The driver output value at any time is equal to the variable value of the signal.
[OPEN_LOOP_MOTIONVIEW]
TAG = 'OPENLOOP'
TYPE = 'MOTIONVIEW'
SIGNAL_CHANNEL = '1'
[OPENLOOPCONTROLLER - MotionView]
TAG Attr- string Required
<OPENLOOP>
TYPE Attr- string Required
<MotionView>
SIGNAL_CHANNEL Attr- int Required
<0 to 4>
Picks up the variable value of the solver variable specified at the same index in user signals in the Signals panel in the driver GUI.
All open loop signals should be linked to a unique channel.
