Running a Model with RMOD-K Tire
Tire result requests are saved in the standard output files (.plt and .abf files), written by MotionSolve. Graphics of the model are stored in the .h3d file, which includes graphics of the hub forces. RMOD-K includes an external animator which allows you to view the tire behavior.
- RMODK_FB_TYRSUB_doku.txt - contains information about the tire and the tire numerical solution.
- RMODK_FB_TYRSUB ROAD_doku.txt - contains information about the road surface being used.
The RMODK tire property file allows you to define the names of the log files.
