HVVH-9500: AutoCompare
HyperMesh Operations Use Case 1
  1. From the AutoCompare tab, select the HM operations tab.
  2. From the Solver Type list, select HM.
  3. Select the Reference compare only check box and deselect Reference files.
    The Current Version drop-down menu is disabled.
  4. From the Reference Version list, select 2020.
  5. Click the file browser icon, , or the add file icon, , to select reference scripts, reference models, and reference files, located in ..\tutorials\hvvh\AutoCompare.
  6. In the Output directory field, click to select an output directory.
  7. Click Apply.
    Scripts are executed on reference models in the reference version and a generated OUT file is compared with the reference files.
    The reference file can be any solver deck or ASCII file.
    The report status is displayed under User Report.
  8. Click HTML Report to open an HTML report, which contains details of the script executed in HyperMesh.
HyperMesh Operations Use Case 2
  3. Deselect the Reference compare only check box and the Reference files check box.
  4. From the Current Version list, select 2020
  5. From the Reference Version list, select 2017.0.
  6. Click the file browser icon, , or the add file icon, , to select reference scripts and reference models, located in ..\tutorials\hvvh\AutoCompare.
  7. In the Output directory field, click to select an output directory.
  8. Click Apply.
    Scripts are executed on reference models in the current version and reference version. An OUT file generated in both versions is compared.
  9. Click HTML Report to open an HTML report, which contains details of the script executed in HyperMesh.
HyperMesh Operations Use Case 3
  3. Select the Reference files check box and deselect the Reference compare only check box.
  6. Click the file browser icon, , or the add file icon, , to select reference scripts, reference models, and reference files, located in ..\tutorials\hvvh\AutoCompare.
  8. Click Apply.
    Use case 3 is a combination of use case 1 and use case 2. It contains two steps:
    • Step 1: Scripts are executed on reference models in the reference version and a generated OUT file is compared with the reference files.
    • Step 2: Scripts are executed on reference models in the current version and a generated OUT file is compared with the OUT file generated in Step 1.
    Reference files can be any solver deck or ASCII file.
