Utility/Data Access
SubroutineUses the AKIMA spline fitting method to return the interpolated value
or n-th derivative of the interpolated value for a Reference_Spline element.
Use
The AKISPL function can be called by any user-defined subroutine.
- Fortran Calling Syntax
- CALL AKISPL (XVAL, ZVAL, ID, IORD, ARRAY, ERRFLG)
- C/C++ Calling Syntax
- c_akispl(xval, zval, id, iord, array, errflg)
- Python Calling Syntax
- [value, eflag] = py_akispl(x, z, id, iord)
- MATLAB Calling Syntax
- [value, eflag] = m_akispl(x, z, id, iord)
Attributes
- ID
- [integer]
- The identifier of the corresponding user defined Reference_Spline element.
- XVAL
- [double precision]
- The independent x value at which the AKIMA spline function is supposed to
interpolate the output value.
- ZVAL
- The independent z value at which the AKIMA spline function is supposed to
interpolate the output value in a 3-D Spline data
- IORD
- [logical]
- The order of derivative returned by the AKISPLINE function
Output
- ARRAY
- The vector output value of dimension 3.
- If IORD is 0, then the returned values are the
interpolated values of y.
- If IORD is 1, then the returned values are the
derivatives of y with respect to x and z.
- If IORD is 2, then the output array contains the second
derivatives of y with respect to xx, xz, and zz, respectively.
- ERRFLG
- [logical]
- The logical variable that is returned to the calling subroutine and that
indicates the success of the AKYSPL function call.
