Using User Subroutines
User subroutines can be used in the same way in optimization as is in a normal analysis.
However, if you choose to use the parallel finite difference method in optimization (the default when finite differencing is selected), then you should be aware of some special restrictions.
The parallel finite differencing approach in MotionSolve uses the Pickle module to communicate and receive data between the multiple processes.
Pickle implements an algorithm for serializing and de-serializing a Python object. “Pickling” is the process for converting a Python object hierarchy into a byte stream, and “unpickling” is the inverse operation, whereby a byte stream is converted back into an object hierarchy.
The parallel finite differencing approach in MotionSolve uses “pickling” and “unpickling” to communicate and receive data between the multiple processes.
from msolve.optimize import *
def calci(id,par,npar):
def function1(……):
Likewise, you should not define the user subroutine as a class method. The class method is not recognized as a top-level object in Python although the class itself might be on the top level. In the following, calci, is not pickleable:
class Fourbar(……):
def calci(self,id,par,npar):
For more details on pickle, refer to the Python documentation on pickle.
