ardi::item::exceldocument
Interact with items of type exceldocument.
Supported property names are: -name -value -parent -type (read only) -file -sheet -caption -caption_location All properties available can be passed via the "create" API or modified on an existing item via the "set" API.
ardi::item::exceldocument create args
- Parameters
- For a full list of property names, see above.
- Returns
- The ID of the item or tcl-error in case an error occurred during creation. i.e ardi::api::item::exceldocument create -name "My External Excel Document Item"
ardi::item::exceldocument delete args
- Parameters
- -id (mandatory)
- value: item ID. The item ID which is returned by the corresponding "create" API.
- Returns
- 1 for ok
ardi::item::exceldocument get args
- Parameters
- -id (mandatory)
- Returns
ardi::item::exceldocument getcell args
- Parameters
- -id (mandatory)
- -row (mandatory)
- value: row ID. Row ID is an integer starting from 0.
- -column (mandatory)
- value: column ID. Column ID is an integer starting from 0.
- -property (mandatory)
- value: property name. 'value' or 'href'.
- Returns
- The value of the specified property or tcl-error in case of error usage: ardi::item::exceldocument getcell -id $id -row 0 -column 0 -property value
ardi::item::exceldocument getpropertyid args
- Parameters
- -id
- value: item ID
- -key
- value: property key
ardi::item::exceldocument getpropertykeylist args
- Parameters
- -id
- value: item ID
- Returns
- list of property keys for a particular item ID
ardi::item::exceldocument set args
- Parameters
- -id (mandatory)
- Returns
ardi::item::exceldocument setcell args
- Parameters
- -id (mandatory)
- -row (mandatory)
- -value
- value: The value you want to set on the cell.
- -href
- value: Object ID to hyperlink.
- Returns
- 1 for ok, tcl-error in case of error I.e ardi::api::item::exceldocument setcell -id $id -row 0 -column 0 -value "Hello" -href $refobjid.
