ardi::item
ardi::item apply args
For better performance data created, manipulated or deleted go into a cache. This API processes the cached data, clears the cache and redraws the GUI if needed.
Returns
1 for ok
tcl-error in case of error
ardi::item delete args
Deletes the item with the specified ID.
-id
value: item ID.
default value: ""
Returns
1 for ok
ardi::item get args
Get property value.
-id
value: item ID,
-property Value: valid property name. To get a complete property list, use ::ardi::item getpropertykeylist
For example, to get the name of the image item, use ::ardi::item get -id $image -property name.
-key
value: property Key. default value: ""
Returns
1 if valid, 0 if invalid
ardi::item getpropertyid args
Queries id of property.
-id
value: item ID
-key
value: property key
ardi::item getpropertykeylist args
Queries list of properties.
-id
value: item ID
Returns
list of property keys for a particular item id.
ardi::item getroot
Queries the ID of the report root item. This is the top most item.
Returns
ardi::item getselection
Queries the currently selected item.
Returns
select item ID.
ardi::item gettype args
Queries the type of the item with the specified ID.
-id
value: item ID.
default value: ""
Returns
the type of the item.
ardi::item gettypelist
Queries available types of items.
Returns
a list of item types.
ardi::item hasproperty
Checks if the item has property with specified key.
-id
value: item ID, default value: ""
-key
Returns
ardi::item isvalid
Checks if the item with the specified ID is valid.
-id
Returns
ardi::item set
Sets property value.
-id
value: item ID,
-property
value: property Key. To get list of all property list, use ::ardi::item getpropertykeylist
value: value to be assigned to property
For example, to change name of the image item to "Model Overview"; we can use ::ardi::item set -id $image -name "Model Overview".
Returns
