ardi::item::slide
Interact with items of type slide.
This item type is valid only for MS-PowerPoint reports. Supported property names are: -name -value -parent -type (read only) -layoutname. All properties available can be passed via the "create" API or modified on an existing item via the "set" API.
ardi::item::slide create args
Creates an item of type "slide".
For a full list of property names, see above.
Returns
The ID of the item or tcl-error in case an error occurred during creation. i.e ardi::api::item::slide create -name "My Slide Item"
ardi::item::slide delete args
Deletes the item with the specified ID.
-id (mandatory)
value: item ID. The item ID which is returned by the corresponding "create" API.
default value: ""
Returns
1 for ok
tcl-error in case of error i.e ardi::api::item::slide delete -id $id
ardi::item::slide get args
Queries the value of one property.
-id (mandatory)
default value: ""
Returns
The value of the specified property or tcl-error in case of error usage: ardi::item::slide get -id $id -property parent
ardi::item::slide getpropertyid args
Queries id of property.
-id
value: item ID
-key
value: property key
ardi::item::slide getpropertykeylist args
Queries list of properties.
-id
value: item ID
Returns
list of property keys for a particular item ID
ardi::item::slide set args
Sets one or multiple parameters to specified values. The type of the item is assigned upon creation and cannot be changed after.
-id (mandatory)
default value: ""
Returns
1 for ok
tcl-error in case of error i.e ardi::api::item::slide set -id $id -name "My Slide Item" -value "Good morning, how are you today?"
