hwIAMFExportOptions GetQuality
Gets the quality used when exporting AMF files using JPEG encoding.
hwIAMFExportOptions_handle GetQuality
HyperView Tcl Query
This command retrieves the quality used when exporting AMF files using JPEG encoding. This is a floating point value between 0 and 100 (exclusive). A large quality means better image fidelity but larger image size.
Note: This parameter is used when exporting AMF files from any client during video capture.
To determine the current quality setting used when exporting AMF files:
mySessionName GetAMFExportOptionsHandle myAmfOptions
myAmfOptions GetQuality
Error
Returns the quality used when exporting JPEG encoded AMF files, otherwise 0 if an error occurs.
