hwIAMFExportOptions SetPalette
Sets the palette used when exporting AMF files.
hwIAMFExportOptions_handle SetPalette type
HyperView Tcl Modify
This command sets the palette used when exporting AMF files.
Note: This parameter is used when exporting AMF files from either the video or animation clients during video capture.
type
The palette type. Options include: "fullcolor" or "grayscale".
To set the palette used when exporting AMF files:
mySessionName GetAMFExportOptionsHandle myAmfOptions
myAmfOptions SetPalette fullcolor
Error
Returns 0 if successful, or an error code (3 = HW_InvalidHandle) - if the handle used to invoke the method is no longer valid or
(HW_InvalidArgs) - if the value of the argument type is not one of those listed above.
