hwIAMFExportOptions SetQuality
Sets the quality used when exporting AMF files using the JPEG encoder.
hwIAMFExportOptions_handle SetQuality quality
HyperView Tcl Modify
This command sets the quality used when exporting AMF files using the JPEG encoder.
Note: This parameter is used when exporting JPEG encoded AMF files from any client during video capture.
quality
The quality to be used when exporting JPEG encoded AMF files. This must be between 0 and 100 (exclusive).
To set the current quality used when exporting JPEG encoded AMF files:
mySessionName GetAMFExportOptionsHandle myAmfOptions
myAmfOptions SetQuality 90
Returns 0 if successful, or an error code (3 = HW_InvalidHandle) - if the handle used to invoke the method is no longer valid or
(HW_InvalidArgs) - if the value of the argument quality is not in the range listed above.
