hwIAMFExportOptions SetSize
Sets the relative image size (percent) used when exporting AMF files.
hwIAMFExportOptions_handle SetSize size
HyperView Tcl Modify
This command sets the relative image size (percent) used when exporting AMF files.
Note: This parameter is used when exporting AMF files from either the video or animation clients during video capture.
size
The relative image size (in percent) to be used when exporting AMF files. Values include: 100, 75, 50, or 33.
To set the current relative image size used when exporting AMF files:
mySessionName GetAMFExportOptionsHandle
myAmfOptions
myAmfOptions SetSize 50
Error
Returns 0 if successful, or an error code (3 = HW_InvalidHandle) - if the handle used to invoke the method is no longer valid or
(HW_InvalidArgs) - if the value of the argument size is not one of those listed above.
