poIAdvancedQuery GetOutputSelectionSethandle
Gets the selection set handle which holds the IDs of the result output.
advancedQuery_handle GetOutputSelectionSethandle querySelectionSet_handle
HyperView Tcl Query
This command is used to get the selection set handle for the output results.
Returns the selection set handle.
To get the selection set handle for the advanced query:
hwi OpenStack
hwi GetActiveClientHandle client
set ruleID [client AddQueryRule extreme]
client GetQueryRuleHandle rule_handle $ruleID
rule_handle SetExtreme "TopN 3"
set advQueryID [client AddAdvancedQuery]
client GetAdvancedQueryHandle advancedQuery_handle $advQueryID
advancedQuery_handle AddSimulations "current" "current"
advancedQuery_handle SetQuery "entity.id entity.value"
advancedQuery_handle SetQueryLogic "[rule_handle GetID]"
advancedQuery_handle GetValueList
advancedQuery_handle GetOutputSelectionSetHandle set_handle
hwi CloseStack
This command returns HW_InvalidHandle, if the core object associated with the advanced query handle does not exist anymore.
