poIImagePlane SetSyncMode
Sets the mode used to synchronize an image plane video with a model animation.
Imageplane_handle SetSyncMode mode
HyperView Tcl Modify
This command automatically adjusts the image plane video scaling based on the selected mode.
mode
Manual (Default)
No changes are made. The synch mode is automatically set to manual if the scaling is changed by the user.
Length
The scaling is adjusted so that the video and model start and stop animating at the same time.
Framerate
The scaling is adjusted so that the video and model animate at the same number of frames per second.
To set the sync mode of an image plane with an index of 1 to "Length":
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetImagePlaneCtrlHandle ipc_handle
ipc_handle GetImagePlaneHandle image_plane_handle 1
image_plane_handle SetSyncMode Length
hwi CloseStack
Returns HW_InvalidHandle if the image plane handle is invalid, or HW_Error if the mode is not a valid string.
