poIPart SetShadeMode
Sets the shading mode. This command overrides the global setting that was set with poIRenderOptions SetShadeMode.
poIPart_handle SetShadeMode mode
HyperView Tcl Modify
This command sets the shading mode. This command overrides the global setting that was set with poIRenderOptions SetShadeMode.
mode
Set to flat or smooth.
Returns 0 if successful, otherwise an error code.
