poIQueryCtrl GetDataSourceList
Gets a list of the available data sources.
poIQueryControl_handle GetDataSourceList
HyperView Tcl Query
This command retrieves a list of the available data sources.
mySessionName GetProjectHandle myProjectName
set pageIndex [myProjectName GetActivePage]
myProjectName GetPageHandle myPageName $pageIndex
set windowIndex [myPageName GetActiveWindow]
myPageName GetWindowHandle myWindowName $windowIndex
myWindowName GetClientHandle myPostName
set modelIndex [myPostName GetActiveModel]
myPostName GetModelHandle myModelName $modelIndex
myModelName GetQueryCtrlHandle myQueryName
myQueryName GetDataSourceList
Returns a list of the data sources available, or an error code (HW_InvalidHandle) if the handle used to invoke the method is no longer valid.
