poIQueryCtrl GetRemoveDuplicates
Gets the state of the remove duplicates option.
poIQueryControl_handle GetRemoveDuplicates
HyperView Tcl Query
This command retrieves the state of the remove duplicates option from the query handle.
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
set sid [model_handle AddSelectionSet node]
model_handle GetSelectioSetHandle selset_handle $sid
selset_handle Add all
model_handle GetQueryCtrlHandle query_handle
set rem_duplicate [query_handle GetRemoveDuplicates]
hwi CloseStack
A bool should always be returned.
