poIRenderOptions SetEnvMapPathAndFormat
Sets the relative path and image format of the environment textures folder.
render_options SetEnvMapPathAndFormat path format
HyperView Tcl Modify
This command sets the relative path and image format of the environment textures folder.
To set the relative path and image format of the environment textures folder:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetRenderOptionsHandle render_options
render_options SetEnvMapPathAndFormat “DefaultStudio” “png”
hwi CloseStack
None.
