poIRenderOptions SetPreloadDataEnabled
Sets the PreLoad Simulation Data state.
poIRenderOptions_handle SetPreloadDataEnabled state
HyperView Tcl Modify
This command sets the PreLoad Simulation Data state.
- state
- Set to true to load data first, then begin animation. Set to false to animate while loading data.
Returns 0 if successful, otherwise an error code.
