Nastran to Radioss Conversion Mapping
Elements
Nastran | Radioss |
CONM2 | /ADMAS |
CWELD | Mesh less weld (feabsord, fe realize using HEXA) |
CELAS1/CELAS2 CDAMP1/CDAMP2 (0 length) |
/SPRING |
PLOTEL | Plot element |
RBAR | /RIVET |
RBE2/RBE3 | /RBODY |
RJOINT | /RLINK |
CBUSH (When using vector) |
/ SPRING3N |
CBUSH1D | /SPRING2N |
CBAR/CBEAM/CBEND | BEAM |
CROD | TRUSS |
CONROD | TRUSS and /PROP/TRUSS |
CTRIA3/CTRIAR CTRIA6 (Change to 1st order before convert) |
/SH3N |
CQUAD4, CQUADR, CSHEAR CQUAD8 (Change to 1st order then convert) |
/SHELL |
CTETRA4 CTETRA10 (Change to 1st order then convert) |
/TETRA4 |
CHEXA8/ CPENTA6 CHEXA20/ CPENTA15 (Change to 1st order then convert) |
/BRICK |
Properties
Nastran | Radioss |
PBAR/PBEAM (Only single section PBEAM is supported) |
/PROP/BEAM |
PBUSH | /PROP/SPR_GENE |
PBUSH1D/PDAMP/PELAS | /PROP/SPRING |
PROD | /PROP/TRUSS |
PSHELL/PSHEAR | /PROP/SHELL |
PSOLID | /PROP/SOLID |
Materials
Nastran | Radioss |
MAT1 | /MAT/ELASTIC |
MAT8 | /MAT/LAW19 |
