Custom Export Options
Options used when exporting data via a custom solver tempalte.
Use the Custom option to export models using your own custom-built export translator, or export models using a translator provided with the HyperWorks installation but which is not directly accessible via the default Export menu.
General
- Export
- Type of entities to export.
- Write Connectors
- Export all of the connectors in the model. This operation appends the master connector file xml data to the end of the solver input file as solver comments and thus does not effect the operation of the solver. This operation can remove the necessity to perform a FE-absorb on a imported model since the connector information is retained in the solver input file.
- Write ID rules
- Export ID management rules defined in the ID Manager as an XML block at
the end of each Include file. Restriction: Available when Include export is set to Preserve.
Warning messages
- Invalid elements
- Display warning message upon invalid elements.
- Overwrite existing file
- Display warning message upon overwriting an existing file.
