Edit Cards
Edit an entity's card. You can edit multiple entities provided they use identical card images.
This option displays the card image of the chosen entity for the current solver template; if a template is not loaded or if the entity does not have any card images associated with the loaded template, an error message displays in the status bar.
For more information on editing cards, see the Card Editor Panel topic.
