Set various states for entities in a model.
Click from the menu bar.
In the Entity State Browser, toggle the Active/Export
options to control the state of entities.
Tip: Right-click on selected entities
to view more options for selecting states.
Option |
Description |
Active |
The active/inactive state is a controllable state whereby the
display of inactive entities will be
turned off from the display in the graphics, the browsers, the display
panel, and any panel entity collectors. It is designed to aid users who
frequently work with large models and need be able to filter and reduce
the number of available or visible entities. Inactive entities are still present
within the model but are removed from access until they are made active
again. |
Export |
The export/do not export state determines whether entities are exported when using the Custom
export option in the Solver Export Options
dialog. Note: This state does not have any effect on the All and
Displayed export options.
The active/inactive and
export/do not export states are independent of each other – one does not affect the
other. Entities that are set inactive are still eligible
for All and Custom export. They are not output when using the Displayed export option
since they are, by definition, not eligible for display.All entities in the current model that have active and export
states are shown in the browser at all times. Each entity is individually controlled via the browser, but
all collected entities contained within a collector
are subsequently set to the same state as the parent collector – control is not
available at the individual collected entity
level.
Changing the state of an assembly has two functions. First, it sets the
state of that assembly directly. Second, it sets the state of all sub-assemblies,
components and multibodies referenced by that assembly to the same state as the
parent assembly.
Include files do not directly contain any states that can be
controlled by the Entity State Browser. Operating on an include
will, instead, operate on all supported entities that are referenced by that
include.
