Create Entities
Add entities to the model.
Do one of the following:
- Right-click in empty space in a browser and select Create > <entity> from the context menu.
- Right-click on a parent level entity folder in a browser and select Create from the context menu.
- Set an entity selector to the desired type, then
right-click in the modeling window and select
Create <entity> from the context menu.Note: Not available for all entity types.
- Select a tool used to create entities on a ribbon.
The entity is created and assigned a default name, ID, and color. - In the Entity Editor, define the entity's parameters.
