Multibody Planes
MADYMO
Card Description
SURFACE.PLANE Rectangular plane.
multibody = BODY
N1 = POINT_1
N2 = POINT_2
N3 = POINT_3
To create a SURFACE under the SYSTEM.REF_SPACE, a reference to a null body must be selected because a reference to a multibody is required when creating a multibody plane. A null body can be created like any other BODY (card image is not relevant and should not be used), Nullbody should be put under the SYSTEM.REF_SPACE assembly.
