MV Gfile Trans
Converts an .obj formatted file into an Altair G format file that can be used as file graphics in an MDL model.
Select file to translate | Select the file that you want to translate. |
Select output filename | Select the output filename and the directory to which you want to save the file. |
Translator options | Choose from the options listed (optional). |
MessageLog | Displays the Message Log. |
Back/Next | Go to the previous or next window. |
Finish | After entering the source file and output file names, click Finish to create the file and exit the dialog. |
