Exporting Tabular Summaries and Nastran Input Decks
From the Export panel in the Load Export utility, you can set the labels and node IDs for Nastran export.
![](../../images/post_processing/nastran_export_panel.png)
Figure 1. Load Export dialog – Export panel
- Format (short or long)
- FEA coordinate system (global or local)
- Determine if coordinate cards should be written in the Nastran input deck
- Select the point from which you want to auto-number node IDs for Nastran export
- Nastran Node ID names and numbers
- Nastran deck format
- The reference frame in which the GRID cards are written
