Task Wizard
The Task Wizard allows you to select the analysis tasks to be run.
The dialog displays options related to the current model in a series of panels. For example, if you have assembled a standalone powertrain model, the task wizard only displays powertrain analysis options.
See the Task Wizard Dialog dialog topic for additional information.
