View a Report
- From the Analysis menu, select View Reports.
- Select a report from the report list.
- Under Model, select Append, Overlay, or Replace.
- Under Overlay options, select Auto fit plots or Auto color plots, if desired.
Click Apply.
The report is appended, overlaid, or replaced.If a report definition already exists, a message is displayed with the following options:
- Overwrite
- Existing definitions are overwritten by new matching definitions, one at a time.
- Overwrite All
- All existing definitions are overwritten by the new matching definitions.
- Stop
- The operation is aborted.
