Loading [MathJax]/jax/output/CommonHTML/jax.js
/ALE/GRID/SPRING
Block Format Keyword Grid nodes are connected with nonlinear springs (those springs have no effect on the material, only on the movement of the grid).
/ALE/GRID/SPRING
Δt0 γ η ν
Vmin
Δt0 Typical time step
(Real)
[s]
γ Nonlinearity factor
Default = 0.0 (Real)
η Damping coefficient
Default = 0.5 (Real)
ν Shear factor
Default = 1.0 (Real)
Vmin Element with a volume less than Vmin will be declared
Default = -1030 (Real)
[m3]
  1. This option is available for 3D analysis only.
  2. Further explanation about this formulation can be found in ALE Formulation in the Radioss Theory Manual.
  3. Effective time step Δt*0 is computed using damping parameter:(1)
    Δt*0=Δt0η+1+η2
