Iform |
Formulation flag.
- = 0 (linear)
- = 1 (maximum)
if
if
- = -1 (minimum)
if
if
(Integer) |
Keyword3 |
A combination of X, Y, and
Z: X, Y, Z, XY, XZ, and XYZ
Keyword5 |
GRNOD or
NODES defines the way to provide slave
nodes. |
M1 |
First master node
number. |
M2 |
Second master node
number. |
IDi |
Slave Node or node group
identifiers (depending on Keyword5) |
