Processing math: 100%
/ANIM/BRICK/VDAMi
Engine Keyword Generates animation files containing a damage variable value as the function of a brick element. These output variables are only compatible with failure model /FAIL/SNCONNECT.
/ANIM/BRICK/VDAMi/Keyword4
Field Content SI Unit Example
VDAMi
VDAM1
Value of damage factor d
VDAM2
Value of damage surface σy0
VDAM3
Value of rupture surface σyf
Keyword4
ijk
Value in Integration Point
i
Integration point number in direction r.
j
Integration point number in direction s.
k
Integration point number in direction t.
  1. If ijk=0, the variable is equal to the maximum of the values of all Gauss points in the element.
