/ANIM/Eltyp/Restype
Engine Keyword Generates animation files containing element data for the specified result. Options used for beam, spring and truss element types.
/ANIM/Eltyp/Restype
Field | Content | SI Unit Example |
Eltyp |
Restype |
- Damage
in springs is defined as the maximum value between time 0 and the current time of
the displacement versus failure displacement ratio:
(1) - For /PROP/TYPE13 (SPR_BEAM) springs, damage direction 1 is traction/compression, 2 and 3 are shear y and z.
- For /PROP/TYPE8 (SPR_GENE) springs, damage directions 1, 2 and 3 are, respectively x, y and z.
- The "SPH outputs" are available with /ANIM/Eltyp = ELEM/Restype (all Restype values; except Restype = THIC or HOURG). The Restype values: DAM1, DAM2 or DAM3 are only available with material LAW24 for brick element.
- Element time step shows in animation only if elementary time step are computed for this element by Radioss. If nodal time step used (/DT/NODA) in computation , then no element time step shows in animation.
