/ANIM/MAT
Engine Keyword Generates animation files with one part for each material.
/ANIM/MAT
  1. By default, one part is defined for each property set.
  2. Solid and spring elements are not affected by this option:
    • Solid parts are always defined by material
    • Spring parts are always defined by property sets
