Curves
Block Format Keyword
View new features for Radioss 2020.1.
Radioss format 2020 uses the 12x extension format.
Block Format Keyword In this group, keywords are used to set default value, global parameter, analysis type, input/output print, damping and ALE and CFD treatment for the whole model. For default value, it is still possible to overwrite in each specific keywords.
Block Format Keyword In Radioss, two node types are available. They use Cartesian coordinate to describe the position of each node.
Block Format Keyword In this group, keywords are used to combine material and property information (/PART), assemble model (/SUBSET) or define a separate model (//SUBMODEL).
Block Format Keyword Interfaces solve the contact and impact conditions between two parts of a model. Several interface types are available in Radioss and use different contact treatments.
Block Format Keyword Monitored volumes could be used for airbag or tire. The monitored volumes must be inside of closed surface.
Block Format Keyword Radioss supports several different kinematic constraints, which are mainly used to impose acceleration, velocity, displacement or temperature in structure or constraint the moving of structure. They are mutually exclusive for each degree-of-freedom (DOF). Two kinematic conditions applied to the same node may be incompatible.
Block Format Keyword In Radioss the following load cases are available. Stress/strain as initial state could be considered by modeling, as well as pressure, gravity, and thermal load.
Block Format Keyword In this group, tools like transformation, frames, skews, and curve are introduced.
Block Format Keyword Below are the transformation types and their description.
Block Format Keyword Defines a scalar value or a vector value defined on a subset of .
Block Format Keyword Defines a function (For example: stress (Y-axis) as a function of strain (X-axis)).
Block Format Keyword Defines a smoothstep analytic function to be used with loads.
Block Format Keyword This describes the function scale and shift.
Block Format Keyword Defines a table with up to four dimensions using data points.
Block Format Keyword Defines a table with up to four dimensions using functions and/or data points.
Block Format Keyword Adaptive Meshing is used in metal forming to divide the element to better describe the geometry. /ADMESH/GLOBAL and /ADMESH/SET are not available for SPMD computation.
Block Format Keyword Time histories output for different element groups, section output, or gauge output are described in this group.
Block Format Keyword Keywords that are still supported, but no longer maintained (*) are considered obsolete.
This manual contains the description of the Keywords for the Radioss Multi-Domain.
This manual describes the interface between Altair Radioss and a user’s subroutines.
The HyperWorks Solver Run Manager is a unified utility that allows the user to start different HyperWorks Solvers.
