/DELINT
Engine Keyword If a slave node is only connected to 2D solid elements that are all deleted, the node is deactivated from the interface.
/DELINT/Keyword2
Data Description SI Unit Example
Keyword2 Activation flag.
ON
OFF (Default)
  1. In 3D, this option has been replaced by Idel interface flag in Starter Input file.
