/DESOBJ
Optimization Keyword This keyword can be used to select a response as the objective function of an optimization run by selecting a response as the objective function. The selected response can either be minimized or maximized based on the inputs specified on this keyword.
/DESOBJ
title
type resp_ID
title Title.
type Optimization type.
= 0
The selected response function is minimized.
= 1
The selected response function is maximized.
No default (Integer)
resp_ID Optimization response identifier defined on /DRESP1 card. This field is used to select a response as the objective of an optimization run.
No default (Integer > 0)
  1. Only one objective can be defined for an optimization run. Therefore, multiple /DESOBJ entries are not allowed in a single solver deck.
  2. This entry is represented as an optimization objective in HyperMesh and HyperCrash.
