/INTER/LAGMUL/TYPE2
Block Format Keyword Describes the Lagrange multiplier interface TYPE2.
- The incompatibility with standard kinematic conditions are checked out automatically in Starter
- Other Lagrange multiplier conditions may be applied to master and slave nodes, unless there is a physical incompatibility
- There is no added mass on master node
- Kinematic conditions are applied to slave and master nodes
/INTER/LAGMUL/TYPE2/inter_ID/unit_ID | |||||||||
inter_title | |||||||||
grnd_IDs | surf_IDm | Isearch | dsearch |
inter_ID | Interface
unit_ID | Unit Identifier (Integer, maximum 10 digits) |
inter_title | Interface
grnd_IDs | Slave nodes group
identifier (Integer) |
surf_IDm | Master surface
Isearch | Search formulation flag
for the closest master segment
(Integer) |
dsearch | Distance for searching
closest master segment Default is the average size of the master segments. (Real) |
- The dsearch is computed as:
(1)
