/MAT/LAW92
Block Format Keyword This law describes the Arruda-Boyce material model, which can be used to model hyperelastic behavior.
A stress vs strain curve can be defined as an input function in order to determine the material parameters by fitting this curve. This law is only compatible with solid elements.
/MAT/LAW92/mat_ID/unit_ID | |||||||||
mat_title | |||||||||
ρi |
μ | D | λm |
Itype | fct_ID | ν | Fscale |
mat_ID | Material identifier. (Integer, maximum 10 digits) |
unit_ID | Unit Identifier. (Integer, maximum 10 digits) |
mat_title | Material title. (Character, maximum 100 characters) |
ρi | Initial density. (Real) |
[kgm3] |
μ | Shear modulus. (Real) |
[Pa] |
D | Material parameter for bulk modulus
computation
K=2D
. Default =1030 (Real) |
[1Pa] |
λm | The limit of stretch Default = 7.0 (Real) |
Itype | Test data type (stress strain curve).
(Integer) |
fct_ID | Function identifier defining engineer
stress vs engineer strain. (Integer) |
ν | Poisson's ratio. Default = 0.495 (Real) |
Fscale | Scale factor for ordinate (stress) in
function fct_ID Default = 1.0 (Real) |
[Pa] |
Example (Rubber with Parameter Input)
#RADIOSS STARTER
/UNIT/1
unit for mat
Mg mm s
#- 2. MATERIALS:
/MAT/LAW92/1/1
Generic RUBBER
# RHO_I
1.000E-9
# mu D LAM
2.8000E+01 1.4000E-1 1000.
# IType fct_ID NU Fscale
#ENDDATA
/END
Example (Rubber with Function Input)
#RADIOSS STARTER
/UNIT/1
unit for mat
Mg mm s
#- 2. MATERIALS:
/MAT/LAW92/1/1
rubber
# RHO_I
1.000E-9
# mu D LAM
1 2 0.495
/FUNCT/2
LAW92 e.strain vs e.stress from uniaxial test(IType=1)
# X Y
0 0
.03 .30
.06 .55
.10 .80
.20 1.4
.30 2.0
.50 2.7
.70 3.4
1.0 4.0
#ENDDATA
/END
- The
Arruda-Boyce energy density.
(1) W=μ5∑i=1ci(λm)2i−2(ˉIi1−3i)+1D(J2−12+ln(J))With(2) c1=12, c2=120, c3=111050, c4=197000 , c5=519673750and(3) ˉI1=ˉλ21+ˉλ22+ˉλ23with ˉλk=J−1/3λ J=λ1λ2λ3
The Cauchy stress is computed as:(4) σi=λiJ∂W∂λi - If the
stress strain curve fct_ID then the material parameters in line 3,
μ
, D and
λm
must be defined and the line 4 input is not used. Poisson’s
ratio is then calculated from the input as:
(5) ν=3K−2μ6K+2μThe bulk modulus is calculated as:(6) K=2DNote: For positive values of shear modulus, μ , and Limit of stretch, λm , this model is always stable. - If the stress strain curve,
fct_ID, is defined then the line 3 input parameters
μ
, D and
λm
are ignored and are automatically identified by fitting of the
provided stress vs strain curve.A nonlinear least squares algorithm is used to fit the Arruda-Boyce parameters. The model is fully incompressible in fitting the Arruda-Boyce constants to the test data, except in the volumetric test.
(7) E=ndata∑k=1(Ntestk−NthkNtestk)2Where E is relative error. The material constants are obtained using a least-squares-fit procedure to minimize the relative error between the theoretical nominal stress and given experimental data.(8) λ1=λ2=λ and λ3=λ−2 with λ=1+εWhere, Ntestk is a stress value from the test data and Nthi is the theoretical nominal stress given by for each engineer strain i.(9) Nthk=∂W∂λkThe nominal stress is computed for each mode assuming the full incompressibility:(10) J=λ1λ2λ3=1- Uniaxial Mode:
(11) λ1=λ and λ2=λ3=λ−12 with λ=1+εSo(12) Nth=∂W∂λ=2μ(λ−λ−2)5∑i=1ici(λm)2i−2ˉIi−11 with ˉI1=λ2+2λ - Equibiaxial Mode:
(13) λ1=λ2=λ and λ3=λ−2 with λ=1+εSo(14) Nth=∂W∂λ=2μ(λ−λ−5)5∑i=1ici(λm)2i−2ˉIi−11 with ˉI1=2λ2+1λ4 - Planar (Shear Mode):
(15) λ1=λ , λ3=1 and λ2=λ−1 with λ=1+εSo(16) Nth=∂W∂λ=2μ(λ−λ−3)5∑i=1ici(λm)2i−2ˉIi−11 with ˉI1=λ2+1+λ−2
- Uniaxial Mode:
- /VISC/PRONY must be used with LAW92 to include viscous effects.
