Iform = 12
Block Format Keyword Up to 4 different sub-materials (solid, liquid, gas and explosives) can be defined by specifying a material identifier and initial volume fraction.
- LAW3 (HYDPLA)
- LAW4 (HYD_JCOOK)
- LAW5 (JWL)
- LAW6 (HYDRO)
- LAW10 (DPRAG1)
- LAW102 (DPRAG2)
- /EOS/LINEAR
- /EOS/POLYNOMIAL
- /EOS/IDEAL-GAS
- /EOS/STIFF-GAS
/MAT/LAW51/mat_ID/unit_ID | |||||||||
mat_title | |||||||||
Blank | |||||||||
Iform |
mat_ID1 |
mat_ID1 | |||||||||
mat_ID2 | |||||||||
mat_ID3 | |||||||||
mat_ID4 |
mat_ID | Material
identifier. (Integer, maximum 10 digits) |
unit_ID | Unit Identifier (Integer, maximum 10 digits) |
mat_title | Material
title. (Character, maximum 100 characters) |
Iform | Formulation flag =
12. (Integer) |
Kinematic viscosity in
shear
. Default = 0 (Real) |
Kinematic viscosity
(volumetric),
which corresponds to Stokes
Hypothesis. Default = 0 (Real) |
mat_ID1 | Material Identifier for
the 1st sub-material which must refer to LAW3, 4, 5, 6, 10, or
102. Mandatory (Integer) |
Initial volumetric
fraction for the 1st sub-material. Default = 0 (Real) |
mat_IDi | (Optional) Material
Identifier from 2nd to 4th sub-material which must refer to LAW3, 4,
5, 6, 10 or 102. Default = 0 (Integer) |
(Optional) Initial
volumetric fraction. (Real) |
/MAT/LAW51/101
99.99% Water-MULTIMAT:AIR+WATER ,units {g,mm,ms}
# RHO_I RHO_0
# IFLG
12
# NU LAMDA
0 0
# MAT_1 ALPHA_1
5 0.9999
# MAT_2 ALPHA_2
4 0.0001
/ALE/MAT/101
# Modif. factor.
0
/UNIT/1
unit for mat
g mm ms
/MAT/HYD_VISC/4/1
AIR_LAW6
# RHO_0
1.22E-4
# Knu Pmin
0 0
/EOS/POLYNOMIAL/4/1
WATER
# C0 C1 C2 C3
0 0 0 0
# C4 C5 E0 Pmin RHO_0
.4 .4 .25 0 1.22E-4
/MAT/HYD_VISC/5/1
Water_LAW6
# RHO_0
.1
# Knu Pmin
0 0
/EOS/POLYNOMIAL/5/1
WATER
# C0 C1 C2 C3
0 208.9 0 0
0 0 0 0 .1
#enddata
- The material law is based on a diffusive interface technique. Numerical diffusion can be improved using MUSCL method for volume fraction (/ALE/MUSCL). The previous /UPWIND used to limit diffusion is now obsolete.
- The sub-materials can be listed in any order, but there can only be one explosive sub-material /MAT/LAW5.
- If 4 sub-materials are requested, at least one of them should be an explosive sub-material /MAT/LAW5.
- Kinematic
viscosities are global and is not specific to each material. They are used to
compute the viscous stress tensor:
(1) Where,- Kinematic viscosity in shear
- Kinematic volumetric viscosity flag
- Volumetric
fractions enable the sharing of elementary volume within the three different
materials.
For each material must be defined between 0 and 1.
Sum of initial volumetric fractions must be equal to 1.
For automatic initial fraction of the volume, refer to the /INIVOL card.
- It is not recommended to use this law with Radioss single precision engine.
