1.out File Examples
The following depicts, for one same model computed with Radioss version 11.0.201, the Engine output (_0001.out) file evolution from an over-estimated to an under-estimated imposed AMS time step.
Over-Estimated /DT/AMS Target Time Step
20 Times the Reference /DT/NODA/CST
Note the progressive switch from element (SOLID) driven time step to interface (INTER) time step drop due to their spring reaction stiffness to finally end with an AMS divergence.
CYCLE TIME TIME-STEP ELEMENT ERROR I-ENERGY K-ENERGY T K-ENERGY R EXT-WORK MAS.ERR
0 0.000 0.3980E-02 SOLID 1026400 0.0% 0.000 0.4134E+06 0.000 -0.1719E-10 0.7671E-02
ANIMATION FILE: DFWDS734_AMS_FULL_REWELD_NOSECT_MAXA001 WRITTEN
10 0.3980E-01 0.3980E-02 SOLID 1026953 0.0% -4.176 0.4134E+06 0.2174 22.59 0.7671E-02
20 0.7960E-01 0.3980E-02 SOLID 1027171 0.0% 8.901 0.4135E+06 0.7490 81.41 0.7671E-02
30 0.1194 0.3980E-02 SOLID 1027865 0.0% 43.57 0.4135E+06 1.742 164.1 0.7671E-02
40 0.1592 0.3980E-02 SOLID 1026669 0.0% 94.41 0.4136E+06 4.155 261.0 0.7671E-02
50 0.1990 0.3980E-02 SOLID 1026928 0.0% 158.0 0.4136E+06 9.559 364.5 0.7671E-02
60 0.2388 0.3980E-02 SOLID 1027135 0.0% 230.8 0.4136E+06 17.50 470.2 0.7671E-02
70 0.2786 0.3980E-02 SOLID 1027670 0.0% 303.5 0.4137E+06 27.21 574.8 0.7671E-02
80 0.3184 0.3980E-02 SOLID 1027755 0.0% 366.8 0.4137E+06 36.79 674.5 0.7671E-02
90 0.3582 0.3980E-02 SOLID 1027323 0.0% 419.8 0.4137E+06 42.80 767.0 0.7671E-02
100 0.3980 0.3980E-02 SOLID 1026690 0.0% 464.3 0.4137E+06 46.51 850.7 0.7671E-02
1100 4.378 0.3980E-02 SOLID 1027754 0.0% 2558. 0.4116E+06 61.59 1016. 0.7671E-02
1110 4.418 0.3980E-02 SOLID 1027894 0.0% 2617. 0.4116E+06 63.80 1002. 0.7671E-02
1120 4.457 0.3980E-02 SOLID 1026231 0.0% 2680. 0.4115E+06 63.67 990.5 0.7671E-02
-- CONSTANT TIME STEP FOR SOLID ELEMENT NUMBER 7004937
1130 4.497 0.3980E-02 SOLID 1027738 0.0% 2744. 0.4114E+06 61.73 980.9 0.7671E-02
1140 4.537 0.3980E-02 SOLID 1027858 -0.1% 2807. 0.4113E+06 59.50 973.5 0.7671E-02
-- CONSTANT TIME STEP FOR SOLID ELEMENT NUMBER 7004935
1150 4.577 0.3980E-02 SOLID 1027880 -0.1% 2867. 0.4113E+06 58.56 968.7 0.7671E-02
1160 4.617 0.3980E-02 SOLID 1027278 -0.1% 2926. 0.4112E+06 59.27 966.8 0.7671E-02
-- CONSTANT TIME STEP FOR SOLID ELEMENT NUMBER 7004933
1170 4.656 0.3980E-02 SOLID 1027327 -0.1% 2984. 0.4111E+06 62.11 968.2 0.7671E-02
-- CONSTANT TIME STEP FOR SOLID ELEMENT NUMBER 7004931
1180 4.696 0.3916E-02 INTER 42009748 -0.1% 3047. 0.4111E+06 66.28 973.2 0.7671E-02
1190 4.735 0.3779E-02 INTER 42009748 -0.1% 3111. 0.4110E+06 72.50 982.0 0.7671E-02
1200 4.772 0.3709E-02 INTER 42009748 -0.1% 3178. 0.4109E+06 80.35 994.9 0.7671E-02
-- CONSTANT TIME STEP FOR SOLID ELEMENT NUMBER 7004929
1210 4.809 0.3628E-02 INTER 42009748 -0.1% 3247. 0.4109E+06 89.95 1012. 0.7671E-02
1220 4.845 0.3591E-02 INTER 42009748 -0.1% 3319. 0.4108E+06 98.18 1033. 0.7671E-02
1230 4.881 0.3659E-02 INTER 42009748 -0.1% 3394. 0.4107E+06 104.3 1060. 0.7671E-02
-- CONSTANT TIME STEP FOR SOLID ELEMENT NUMBER 7004927
1240 4.917 0.3621E-02 INTER 42009748 -0.1% 3474. 0.4107E+06 108.6 1090. 0.7671E-02
1250 4.954 0.3656E-02 INTER 42009748 -0.1% 3561. 0.4106E+06 113.7 1124. 0.7671E-02
1260 4.990 0.3622E-02 INTER 42009748 -0.1% 3656. 0.4105E+06 117.2 1159. 0.7671E-02
ANIMATION FILE: DFWDS734_AMS_FULL_REWELD_NOSECT_MAXA002 WRITTEN
1270 5.026 0.3631E-02 INTER 42009748 -0.1% 3760. 0.4105E+06 122.4 1194. 0.7671E-02
1280 5.062 0.3585E-02 INTER 42009748 -0.1% 3865. 0.4104E+06 122.7 1226. 0.7671E-02
1290 5.098 0.3567E-02 INTER 42009748 -0.1% 3972. 0.4103E+06 125.0 1255. 0.7671E-02
1300 5.133 0.3578E-02 INTER 42009748 -0.1% 4074. 0.4102E+06 126.3 1280. 0.7671E-02
39500 79.47 0.6686E-03 INTER 42009748 -9.4% 0.2141E+06 0.1554E+06 1465. -4253. 0.7671E-02
-- RUPTURE OF SHELL ELEMENT NUMBER 873536
-- RUPTURE OF SHELL ELEMENT NUMBER 873327
39510 79.48 0.6686E-03 INTER 42009748 -9.4% 0.2141E+06 0.1554E+06 1465. -4254. 0.7671E-02
-- RUPTURE OF SHELL ELEMENT NUMBER 873995
39520 79.48 0.6685E-03 INTER 42009748 -9.4% 0.2141E+06 0.1554E+06 1466. -4255. 0.7671E-02
-- RUPTURE OF SHELL ELEMENT NUMBER 872733
39530 79.49 0.6684E-03 INTER 42009748 -9.4% 0.2141E+06 0.1554E+06 1466. -4256. 0.7671E-02
-- RUPTURE OF SHELL ELEMENT NUMBER 876109
-- RUPTURE OF SHELL ELEMENT NUMBER 876112
39540 79.50 0.6684E-03 INTER 42009748 -9.4% 0.2141E+06 0.1554E+06 1467. -4257. 0.7671E-02
-- RUPTURE OF SHELL ELEMENT NUMBER 874081
-- RUPTURE OF SHELL ELEMENT NUMBER 874082
** ERROR : AMS IS LIKELY DIVERGING:
TOTAL C.G. ITERATION NUMBER = 1000 AT CYCLE NUMBER 39550
39550 79.50 0.6685E-03 INTER 42009748 NaN% 0.2141E+06 NaN NaN -4258. 0.7671E-02
** CPU USER TIME **
Case: AMSmaxi_ x20 _ div 79.5stop_32cpu_14.5h_ 110201 sep30
Almost Acceptable /DT/AMS Target Time Step
13 Times the Reference /DT/NODA/CST
Note the late switch from element (SH3N and SOLID) driven time step to interface (INTER) time step drop due to their spring reaction stiffness and node (NODE) driven due to rotations whereas element translation was initially controlling the time step.
0 0.000 0.2736E-02 SOLID 1026805 0.0% 0.000 0.4134E+06 0.000 .1719E-10 0.7671E-02
ANIMATION FILE: DFWDS734_AMS_FULL_REWELD_NOSECT_OPT1A001 WRITTEN
10 0.2736E-01 0.2736E-02 SOLID 1026339 0.0% -9.938 0.4134E+06 0.9492E-01 11.27 0.7671E-02
20 0.5472E-01 0.2736E-02 SH_3N 980467 0.05% -2.140 0.4135E+06 0.2769 41.40 0.7671E-02
30 0.8209E-01 0.2736E-02 SH_3N 983904 0.0% 12.94 0.4135E+06 0.7553 86.61 0.7671E-02
40 0.1094 0.2736E-02 SOLID 1025858 0.0% 34.57 0.4135E+06 1.560 142.9 0.7671E-02
50 0.1368 0.2736E-02 SOLID 1026994 0.0% 65.14 0.4136E+06 2.777 207.0 0.7671E-02
60 0.1642 0.2736E-02 SH_3N 979591 0.0% 102.8 0.4136E+06 4.844 276.2 0.7671E-02
70 0.1915 0.2736E-02 SH_3N 1011870 0.0% 147.1 0.4136E+06 8.051 348.0 0.7671E-02
80 0.2189 0.2736E-02 SOLID 1027827 0.0% 197.0 0.4136E+06 12.51 421.2 0.7671E-02
90 0.2463 0.2736E-02 SOLID 1025763 0.0% 249.5 0.4136E+06 17.97 494.7 0.7671E-02
100 0.2736 0.2736E-02 SOLID 1026760 0.0% 300.5 0.4137E+06 24.45 567.3 0.7671E-02
-- RUPTURE OF SHELL ELEMENT NUMBER 9861056
5500 15.04 0.2736E-02 SH_3N 980451 -1.0% 0.3598E+05 0.3741E+06 377.9 1060. 0.7671E-02
5510 15.06 0.2736E-02 SH_3N 980451 -1.0% 0.3607E+05 0.3740E+06 379.4 1048. 0.7671E-02
5520 15.09 0.2736E-02 SH_3N 980440 -1.0% 0.3614E+05 0.3739E+06 380.1 1035. 0.7671E-02
5530 15.12 0.2736E-02 SH_3N 983880 -1.0% 0.3623E+05 0.3738E+06 379.8 1021. 0.7671E-02
5540 15.15 0.2736E-02 SH_3N 1012368 -1.0% 0.3630E+05 0.3737E+06 379.0 1005. 0.7671E-02
5550 15.17 0.2736E-02 SH_3N 980451 -1.0% 0.3638E+05 0.3736E+06 377.9 987.8 0.7671E-02
-- RUPTURE OF SHELL ELEMENT NUMBER 9897179
5560 15.20 0.2736E-02 SH_3N 980112 -1.0% 0.3645E+05 0.3735E+06 377.0 969.7 0.7671E-02
-- RUPTURE OF SHELL ELEMENT NUMBER 9896885
5570 15.23 0.2736E-02 SH_3N 1015803 -1.0% 0.3652E+05 0.3734E+06 376.7 950.6 0.7671E-02
-- RUPTURE OF SHELL ELEMENT NUMBER 9897148
5580 15.26 0.2736E-02 SH_3N 1012363 -1.0% 0.3659E+05 0.3733E+06 377.0 930.5 0.7671E-02
5590 15.28 0.2736E-02 SH_3N 1018445 -1.0% 0.3666E+05 0.3732E+06 377.9 909.5 0.7671E-02
5600 15.31 0.2736E-02 SH_3N 971703 -1.0% 0.3673E+05 0.3731E+06 378.8 887.8 0.7671E-02
18200 48.77 0.2393E-02 INTER 42009748 -6.2% 0.1561E+06 0.2282E+06 888.8 -2873. 0.7671E-02
-- CONSTANT TIME STEP FOR SOLID ELEMENT NUMBER 7001813
18210 48.79 0.2431E-02 INTER 42009748 -6.2% 0.1562E+06 0.2281E+06 889.2 -2873. 0.7671E-02
-- CONSTANT TIME STEP FOR SOLID ELEMENT NUMBER 7002310
-- CONSTANT TIME STEP FOR SOLID ELEMENT NUMBER 7001709
18220 48.82 0.2495E-02 INTER 42009748 -6.2% 0.1563E+06 0.2280E+06 888.3 -2872. 0.7671E-02
18230 48.84 0.2607E-02 INTER 42009748 -6.2% 0.1564E+06 0.2279E+06 891.0 -2870. 0.7671E-02
-- CONSTANT TIME STEP FOR SOLID ELEMENT NUMBER 7001821
-- CONSTANT TIME STEP FOR SOLID ELEMENT NUMBER 7002666
18240 48.87 0.2668E-02 NODE 10103704 -6.2% 0.1564E+06 0.2278E+06 893.2 -2869. 0.7671E-02
-- CONSTANT TIME STEP FOR SOLID ELEMENT NUMBER 7002205
18250 48.90 0.2665E-02 NODE 10103704 -6.2% 0.1565E+06 0.2277E+06 896.1 -2867. 0.7671E-02
18260 48.92 0.2663E-02 NODE 10103704 -6.2% 0.1566E+06 0.2276E+06 897.3 -2865. 0.7671E-02
-- CONSTANT TIME STEP FOR SOLID ELEMENT NUMBER 7001710
18270 48.95 0.2614E-02 INTER 42009748 -6.2% 0.1567E+06 0.2275E+06 897.7 -2863. 0.7671E-02
18280 48.98 0.2599E-02 INTER 42009748 -6.2% 0.1568E+06 0.2274E+06 895.9 -2861. 0.7671E-02
-- CONSTANT TIME STEP FOR SOLID ELEMENT NUMBER 7001702
18290 49.00 0.2655E-02 NODE 10103704 -6.2% 0.1568E+06 0.2273E+06 895.6 -2860. 0.7671E-02
18300 49.03 0.2736E-02 SH_3N 979131 -6.2% 0.1569E+06 0.2272E+06 896.7 -2859. 0.7671E-02
37100 99.69 0.2612E-02 INTER 42009748 -9.4% 0.2150E+06 0.1548E+06 1712. -3241. 0.7671E-02
37110 99.71 0.2633E-02 INTER 42009748 -9.4% 0.2150E+06 0.1548E+06 1712. -3239. 0.7671E-02
-- RUPTURE OF SHELL ELEMENT NUMBER 872981
37120 99.74 0.2631E-02 INTER 42009748 -9.4% 0.2150E+06 0.1549E+06 1711. -3237. 0.7671E-02
-- RUPTURE OF SHELL ELEMENT NUMBER 876845
37130 99.77 0.2630E-02 INTER 42009748 -9.4% 0.2150E+06 0.1549E+06 1711. -3235. 0.7671E-02
-- RUPTURE OF SHELL ELEMENT NUMBER 877165
37140 99.79 0.2627E-02 INTER 42009748 -9.4% 0.2150E+06 0.1549E+06 1710. -3233. 0.7671E-02
-- RUPTURE OF SHELL ELEMENT NUMBER 872868
37150 99.82 0.2609E-02 INTER 42009748 -9.4% 0.2150E+06 0.1549E+06 1709. -3231. 0.7671E-02
-- RUPTURE OF SHELL ELEMENT NUMBER 877277
-- RUPTURE OF SHELL ELEMENT NUMBER 877278
37160 99.84 0.2669E-02 INTER 42009748 -9.4% 0.2150E+06 0.1549E+06 1709. -3229. 0.7671E-02
-- RUPTURE OF SHELL ELEMENT NUMBER 877051
37170 99.87 0.2671E-02 INTER 42009748 -9.4% 0.2150E+06 0.1549E+06 1708. -3227. 0.7671E-02
-- RUPTURE OF SHELL ELEMENT NUMBER 876266
37180 99.90 0.2671E-02 INTER 42009748 -9.4% 0.2150E+06 0.1549E+06 1706. -3225. 0.7671E-02
37190 99.92 0.2660E-02 INTER 42009748 -9.4% 0.2150E+06 0.1549E+06 1705. -3224. 0.7671E-02
37200 99.95
0.2643E-02 INTER 42009748 -9.4% 0.2150E+06 0.1549E+06 1704. -3223. 0.7671E-02
37210 99.98 0.2643E-02 INTER 42009748 -9.4% 0.2150E+06 0.1549E+06 1703. -3222. 0.7671E-02
ANIMATION FILE: DFWDS734_AMS_FULL_REWELD_NOSECT_OPT1A021 WRITTEN
37220 100.0 0.2623E-02 INTER 42009748 -9.4% 0.2150E+06 0.1549E+06 1703. -3221. 0.7671E-02
RESTART FILES: DFWDS734_AMS_FULL_REWELD_NOSECT_OPT1_0001_[0001-0004].rst WRITTEN
** CPU USER TIME **
Case: AMSopt1_x13_16cpu_26h_110201sep30
12.5 Times the Reference /DT/NODA/CST
Note the essentially element (SH3N) driven time step with exceptional interface (INTER) time step influence and no node (NODE) driven time step.
CYCLE TIME TIME-STEP ELEMENT ERROR I-ENERGY K-ENERGY T K-ENERGY R EXT-WORK MAS.ERR 0 0.000 0.2487E-02 SH_3N 987177 0.0% 0.000 0.4134E+06 0.000 -0.1719E-10 0.7671E-02 ANIMATION FILE: DFWDS734_AMS_FULL_REWELD_NOSECT_OPTA001 WRITTEN 10 0.2487E-01 0.2487E-02 SH_3N 1004312 0.0% -11.02 0.4134E+06 0.7503E-01 9.448 0.7671E-02 20 0.4975E-01 0.2487E-02 SH_3N 994772 0.0% -2.833 0.4135E+06 0.2556 34.67 0.7671E-02 30 0.7462E-01 0.2487E-02 SH_3N 980477 0.0% 8.087 0.4135E+06 0.5928 73.10 0.7671E-02 40 0.9950E-01 0.2487E-02 SH_3N 980465 0.0% 25.51 0.4135E+06 1.253 121.5 0.7671E-02 50 0.1244 0.2487E-02 SH_3N 994783 0.0% 50.64 0.4135E+06 2.161 177.3 0.7671E-02 60 0.1492 0.2487E-02 SH_3N 983873 0.0% 81.66 0.4136E+06 3.542 238.2 0.7671E-02 70 0.1741 0.2487E-02 SH_3N 983929 0.0% 118.5 0.4136E+06 5.751 302.3 0.7671E-02 80 0.1990 0.2487E-02 SH_3N 980233 0.0% 160.6 0.4136E+06 9.149 368.2 0.7671E-02 90 0.2239 0.2487E-02 SH_3N 980624 0.0% 206.9 0.4136E+06 13.47 434.9 0.7671E-02 100 0.2487 0.2487E-02 SH_3N 985772 0.0% 254.8 0.4136E+06 18.63 501.6 0.7671E-02 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4980 12.39 0.2487E-02 SH_3N 983878 -0.7% 0.2624E+05 0.3855E+06 319.2 1427. 0.7671E-02 4990 12.41 0.2487E-02 SH_3N 983854 -0.7% 0.2633E+05 0.3854E+06 317.9 1422. 0.7671E-02 5000 12.44 0.2487E-02 SH_3N 980375 -0.7% 0.2642E+05 0.3852E+06 317.3 1416. 0.7671E-02>
-- RUPTURE OF SHELL ELEMENT NUMBER 9897228
5010 12.46 0.2487E-02 SH_3N 986833 -0.7% 0.2651E+05 0.3851E+06 317.1 1409. 0.7671E-02
5020 12.49 0.2487E-02 SH_3N 980402 -0.7% 0.2660E+05 0.3850E+06 316.0 1402. 0.7671E-02
5030 12.51 0.2487E-02 SH_3N 978799 -0.7% 0.2669E+05 0.3849E+06 316.4 1393. 0.7671E-02
-- RUPTURE OF SHELL ELEMENT NUMBER 9897051
5040 12.54 0.2440E-02 INTER 42009748 -0.7% 0.2679E+05 0.3848E+06 316.3 1384. 0.7671E-02
-- RUPTURE OF SHELL ELEMENT NUMBER 9897049
5050 12.56 0.2473E-02 INTER 42009748 -0.7% 0.2687E+05 0.3847E+06 316.3 1375. 0.7671E-02
-- RUPTURE OF SHELL ELEMENT NUMBER 9897202
-- RUPTURE OF SHELL ELEMENT NUMBER 9897044
5060 12.59 0.2487E-02 SH_3N 985187 -0.7% 0.2696E+05 0.3846E+06 317.1 1364. 0.7671E-02
5070 12.61 0.2487E-02 SH_3N 983885 -0.7% 0.2705E+05 0.3845E+06 318.2 1353. 0.7671E-02
5080 12.64 0.2487E-02 SH_3N 980507 -0.7% 0.2713E+05 0.3844E+06 319.4 1342. 0.7671E-02
40000 99.43 0.2487E-02 SH_3N 983740 -6.5% 0.2268E+06 0.1548E+06 1688. -3544. 0.7671E-02
40010 99.46 0.2487E-02 SH_3N 981895 -6.5% 0.2268E+06 0.1548E+06 1691. -3540. 0.7671E-02
40020 99.48 0.2487E-02 SH_3N 984028 -6.5% 0.2268E+06 0.1548E+06 1694. -3536. 0.7671E-02
40030 99.51 0.2487E-02 SH_3N 982888 -6.5% 0.2268E+06 0.1549E+06 1697. -3532. 0.7671E-02
40040 99.53 0.2487E-02 SH_3N 993482 -6.5% 0.2268E+06 0.1549E+06 1700. -3528. 0.7671E-02
40050 99.55 0.2487E-02 SH_3N 1002607 -6.5% 0.2268E+06 0.1549E+06 1703. -3525. 0.7671E-02
40060 99.58 0.2487E-02 SH_3N 986010 -6.5% 0.2268E+06 0.1549E+06 1706. -3521. 0.7671E-02
40070 99.60 0.2487E-02 SH_3N 981287 -6.5% 0.2268E+06 0.1549E+06 1708. -3518. 0.7671E-02
-- RUPTURE OF SHELL ELEMENT NUMBER 876247
40080 99.63 0.2487E-02 SH_3N 993747 -6.5% 0.2268E+06 0.1549E+06 1711. -3515. 0.7671E-02
-- RUPTURE OF SHELL ELEMENT NUMBER 876267
40090 99.65 0.2487E-02 SH_3N 969592 -6.5% 0.2268E+06 0.1549E+06 1712. -3512. 0.7671E-02
40100 99.68 0.2487E-02 SH_3N 985183 -6.5% 0.2268E+06 0.1549E+06 1713. -3510. 0.7671E-02
-- RUPTURE OF SHELL ELEMENT NUMBER 876245
40110 99.70 0.2487E-02 SH_3N 979126 -6.5% 0.2268E+06 0.1549E+06 1710. -3507. 0.7671E-02
40120 99.73 0.2487E-02 SH_3N 981287 -6.4% 0.2269E+06 0.1549E+06 1705. -3504. 0.7671E-02
-- RUPTURE OF SHELL ELEMENT NUMBER 876374
40130 99.75 0.2487E-02 SH_3N 985787 -6.4% 0.2269E+06 0.1549E+06 1699. -3501. 0.7671E-02
40140 99.78 0.2487E-02 SH_3N 981843 -6.4% 0.2269E+06 0.1549E+06 1694. -3498. 0.7671E-02
40150 99.80 0.2487E-02 SH_3N 986153 -6.4% 0.2269E+06 0.1549E+06 1691. -3495. 0.7671E-02
40160 99.83 0.2487E-02 SH_3N 993115 -6.4% 0.2269E+06 0.1549E+06 1689. -3492. 0.7671E-02
40170 99.85 0.2487E-02 SH_3N 995959 -6.4% 0.2269E+06 0.1549E+06 1688. -3490. 0.7671E-02
40180 99.88 0.2487E-02 SH_3N 979140 -6.4% 0.2269E+06 0.1549E+06 1688. -3487. 0.7671E-02
40190 99.90 0.2487E-02 SH_3N 985244 -6.4% 0.2269E+06 0.1549E+06 1689. -3485. 0.7671E-02
40200 99.93 0.2487E-02 SH_3N 993949 -6.4% 0.2269E+06 0.1549E+06 1691. -3483. 0.7671E-02
40210 99.95 0.2487E-02 SH_3N 988714 -6.4% 0.2269E+06 0.1550E+06 1694. -3481. 0.7671E-02
40220 99.98 0.2487E-02 SH_3N 986153 -6.4% 0.2269E+06 0.1550E+06 1697. -3479. 0.7671E-02
ANIMATION FILE: DFWDS734_AMS_FULL_REWELD_NOSECT_OPTA021 WRITTEN
40230 100.0 0.2487E-02 SH_3N 980714 -6.4% 0.2269E+06 0.1550E+06 1698. -3477. 0.7671E-02
RESTART FILES: DFWDS734_AMS_FULL_REWELD_NOSECT_OPT_0001_[0001-0004].rst WRITTEN
** CPU USER TIME **
Case: AMSopt_x12.5_32cpu_17.8h_110201sep30
Under-estimated /DT/AMS Target Time Step
10 Times the Reference /DT/NODA/CST
0 0.000 0.1990E-02 SOLID 1026809 0.0% 0.000 0.4134E+06 0.000 -0.1719E-10 0.7671E-02
ANIMATION FILE: DFWDS734_AMS_FULL_REWELD_NOSECTA001 WRITTEN
10 0.1990E-01 0.1990E-02 SOLID 1027233 0.0% -12.55 0.4134E+06 0.4509E-01 6.263 0.7671E-02
20 0.3980E-01 0.1990E-02 SOLID 1026793 0.0% -3.404 0.4134E+06 0.1923 22.77 0.7671E-02
30 0.5970E-01 0.1990E-02 SOLID 1026919 0.0% -0.3391 0.4135E+06 0.3412 48.73 0.7671E-02
40 0.7960E-01 0.1990E-02 SOLID 1026987 0.0% 11.02 0.4135E+06 0.7014 82.15 0.7671E-02
50 0.9950E-01 0.1990E-02 SOLID 1027291 0.0% 25.55 0.4135E+06 1.259 121.6 0.7671E-02
60 0.1194 0.1990E-02 SOLID 1026789 0.0% 45.07 0.4135E+06 1.935 165.8 0.7671E-02
70 0.1393 0.1990E-02 SOLID 1026910 0.0% 68.49 0.4136E+06 2.833 213.5 0.7671E-02
80 0.1592 0.1990E-02 SOLID 1027497 0.0% 95.78 0.4136E+06 4.219 263.7 0.7671E-02
90 0.1791 0.1990E-02 SOLID 1027432 0.0% 126.7 0.4136E+06 6.282 315.5 0.7671E-02
100 0.1990 0.1990E-02 SOLID 1027197 0.0% 160.8 0.4136E+06 9.184 368.2 0.7671E-02
6220 12.38 0.1990E-02 SOLID 1027341 -0.6% 0.2623E+05 0.3856E+06 304.8 1425. 0.7671E-02
-- RUPTURE OF SHELL ELEMENT NUMBER 9897042
6230 12.40 0.1990E-02 SOLID 1026467 -0.6% 0.2630E+05 0.3856E+06 304.8 1422. 0.7671E-02
6240 12.42 0.1990E-02 SOLID 1027168 -0.7% 0.2637E+05 0.3855E+06 303.9 1418. 0.7671E-02
6250 12.44 0.1990E-02 SOLID 1026994 -0.7% 0.2645E+05 0.3854E+06 303.5 1413. 0.7671E-02
6260 12.46 0.1990E-02 SOLID 1026918 -0.7% 0.2652E+05 0.3853E+06 302.8 1408. 0.7671E-02
6270 12.48 0.1990E-02 SOLID 1027344 -0.7% 0.2659E+05 0.3852E+06 301.9 1402. 0.7671E-02
-- RUPTURE OF SHELL ELEMENT NUMBER 9897040
6280 12.50 0.1990E-02 SOLID 1027487 -0.7% 0.2667E+05 0.3851E+06 300.8 1395. 0.7671E-02
-- RUPTURE OF SHELL ELEMENT NUMBER 9897152
6290 12.52 0.1990E-02 SOLID 1027341 -0.7% 0.2674E+05 0.3850E+06 300.0 1388. 0.7671E-02
6300 12.54 0.1990E-02 SOLID 1027156 -0.7% 0.2681E+05 0.3849E+06 299.5 1381. 0.7671E-02
6310 12.56 0.1990E-02 SOLID 1027292 -0.7% 0.2688E+05 0.3849E+06 299.1 1372. 0.7671E-02
-- RUPTURE OF SHELL ELEMENT NUMBER 9897037
6320 12.58 0.1990E-02 SOLID 1026512 -0.7% 0.2696E+05 0.3848E+06 299.1 1364. 0.7671E-02
-- CONSTANT TIME STEP FOR SOLID ELEMENT NUMBER 7004883
6330 12.60 0.1990E-02 SOLID 1027473 -0.7% 0.2702E+05 0.3847E+06 299.6 1355. 0.7671E-02
6340 12.62 0.1990E-02 SOLID 1027340 -0.7% 0.2709E+05 0.3846E+06 300.6 1346. 0.7671E-02
6350 12.64 0.1990E-02 SOLID 1027345 -0.7% 0.2716E+05 0.3845E+06 301.1 1337. 0.7671E-02
49970 99.44 0.1990E-02 SOLID 1026732 -7.5% 0.2226E+06 0.1550E+06 1683. -3546. 0.7671E-02
-- RUPTURE OF SHELL ELEMENT NUMBER 878377
49980 99.46 0.1990E-02 SOLID 1027394 -7.5% 0.2226E+06 0.1550E+06 1683. -3543. 0.7671E-02
49990 99.48 0.1990E-02 SOLID 1026474 -7.5% 0.2226E+06 0.1550E+06 1683. -3541. 0.7671E-02
50000 99.50 0.1990E-02 SOLID 1026918 -7.5% 0.2226E+06 0.1550E+06 1683. -3538. 0.7671E-02
50010 99.52 0.1990E-02 SOLID 1026842 -7.5% 0.2226E+06 0.1550E+06 1684. -3536. 0.7671E-02
-- RUPTURE OF SHELL ELEMENT NUMBER 877707
50020 99.54 0.1990E-02 SOLID 1026846 -7.5% 0.2226E+06 0.1550E+06 1684. -3533. 0.7671E-02
50030 99.56 0.1990E-02 SOLID 1026916 -7.5% 0.2226E+06 0.1550E+06 1685. -3531. 0.7671E-02
50040 99.58 0.1990E-02 SOLID 1026846 -7.5% 0.2226E+06 0.1550E+06 1686. -3529. 0.7671E-02
50050 99.60 0.1990E-02 SHELL 389951 -7.4% 0.2226E+06 0.1550E+06 1686. -3526. 0.7671E-02
50060 99.62 0.1990E-02 SOLID 1026916 -7.4% 0.2226E+06 0.1550E+06 1686. -3524. 0.7671E-02
50070 99.64 0.1990E-02 SOLID 1027698 -7.4% 0.2226E+06 0.1551E+06 1687. -3522. 0.7671E-02
50080 99.66 0.1990E-02 SHELL 389982 -7.4% 0.2227E+06 0.1551E+06 1687. -3520. 0.7671E-02
-- RUPTURE OF SHELL ELEMENT NUMBER 877600
50090 99.68 0.1990E-02 SHELL 390246 -7.4% 0.2227E+06 0.1551E+06 1688. -3518. 0.7671E-02
-- RUPTURE OF SHELL ELEMENT NUMBER 872853
50100 99.70 0.1990E-02 SOLID 1026474 -7.4% 0.2227E+06 0.1551E+06 1688. -3515. 0.7671E-02
50110 99.72 0.1990E-02 SOLID 1026911 -7.4% 0.2227E+06 0.1551E+06 1689. -3513. 0.7671E-02
50120 99.74 0.1990E-02 SOLID 1026914 -7.4% 0.2227E+06 0.1551E+06 1689. -3511. 0.7671E-02
-- RUPTURE OF SHELL ELEMENT NUMBER 877814
50130 99.76 0.1990E-02 SOLID 1026500 -7.4% 0.2227E+06 0.1551E+06 1690. -3508. 0.7671E-02
-- RUPTURE OF SHELL ELEMENT NUMBER 875485
50140 99.78 0.1990E-02 SOLID 1027163 -7.4% 0.2227E+06 0.1551E+06 1690. -3506. 0.7671E-02
-- RUPTURE OF SHELL ELEMENT NUMBER 880641
50150 99.80 0.1990E-02 SOLID 1026107 -7.4% 0.2227E+06 0.1551E+06 1690. -3504. 0.7671E-02
50160 99.82 0.1990E-02 SOLID 1027004 -7.4% 0.2227E+06 0.1551E+06 1691. -3501. 0.7671E-02
-- RUPTURE OF SHELL ELEMENT NUMBER 877598
50170 99.84 0.1990E-02 SOLID 1026998 -7.4% 0.2227E+06 0.1551E+06 1690. -3499. 0.7671E-02
50180 99.86 0.1990E-02 SHELL 390073 -7.4% 0.2227E+06 0.1551E+06 1690. -3497. 0.7671E-02
-- RUPTURE OF SHELL ELEMENT NUMBER 877149
50190 99.88 0.1990E-02 SHELL 254450 -7.4% 0.2227E+06 0.1551E+06 1690. -3495. 0.7671E-02
50200 99.90 0.1990E-02 SOLID 1026757 -7.4% 0.2227E+06 0.1551E+06 1690. -3493. 0.7671E-02
-- RUPTURE OF SHELL ELEMENT NUMBER 880538
50210 99.92 0.1990E-02 SOLID 1026603 -7.4% 0.2227E+06 0.1551E+06 1690. -3491. 0.7671E-02
50220 99.94 0.1990E-02 SOLID 1027433 -7.4% 0.2227E+06 0.1551E+06 1690. -3489. 0.7671E-02
-- RUPTURE OF SHELL ELEMENT NUMBER 877599
50230 99.96 0.1990E-02 SOLID 1026799 -7.4% 0.2227E+06 0.1551E+06 1690. -3488. 0.7671E-02
50240 99.98 0.1990E-02 SOLID 1027571 -7.4% 0.2227E+06 0.1551E+06 1690. -3486. 0.7671E-02
50250 100.0 0.1990E-02 SOLID 1027536 -7.4% 0.2227E+06 0.1552E+06 1690. -3485. 0.7671E-02
-- RUPTURE OF SHELL ELEMENT NUMBER 872739
ANIMATION FILE: DFWDS734_AMS_FULL_REWELD_NOSECTA021 WRITTEN
-- RUPTURE OF SHELL ELEMENT NUMBER 872967
RESTART FILES: DFWDS734_AMS_FULL_REWELD_NOSECT_0001_[0001-0004].rst WRITTEN
** CPU USER TIME **
Case: AMSnorm_x10_16cpu_33.7h_110201sep30
