Capabilities and Limitations
Kinematic Conditions
- Boundary conditions: /BCS
- Imposed velocities: /IMPVEL
- Imposed displacements: /IMPDISP
- Imposed accelerations: /IMPACC
- Tied contacts: /INTER/TYPE2
Spotflag 0, 1, 2 (kinematic formulation), 25, 27 or 28 (penalty
formulation)
- Rigid bodies: /RBODY (provided they are not sensor activated or deactivated)
- Fixed rigid walls: /RWALL with node_ID= 0 or blank (in case of friction, it is still advised to use a rigid meshed impactor, due to AMS cost)
- Moving rigid walls: /RWALL with node_ID > 0 (in case of friction, it is still advised to use a rigid meshed impactor, due to AMS cost)
- Rigid links: /RLINK
- Kinematic joints: /KJOINT (/PROP/TYPE33) and /KJOINT2 (/PROP/TYPE45)
- Cylindrical joints: /CYL_JOINT
- Active sections: /SECT
- Velocities: /VEL/TRA or /VEL/ROT
- /INIV/TRA or /INIV/ROT
- Rigid bodies can be activated and deactivated with /RBODY/ON and OFF as Engine keywords
- Rigid elements: /RBE2
- Interpolation constraint elements: /RBE3
- Elements:
- All classical: trusses, beams, springs, shells, and solids
- 4-node tetra: /TETRA4, only if Itetra=0
- 10-node tetra: /TETRA10
- Element formulation:
- QEPH Ishell=24 and all other Ishell options
- HEPH Isolid=24
- Interfaces: /DT/AMS is only compatible with interfaces:
- TYPE2 (see Tied contacts above)
- TYPE7
- TYPE10
- TYPE11
- TYPE19
- TYPE21
- TYPE24
- Dynamic relaxation: /DYREL
- Rayleigh damping: /DAMP
- /DT/Eltyp/Keyword3 is compatible with /DT/AMS
(except, /DT/INTER/CST that only applies to the nodes not
concerned by /DT/AMS, that is, nodes not belonging to the
part group (grpart_ID) declared in Starter /AMS, similarly
to /DT/NODA/CST). This includes
/DT/Eltyp/CST for which the small strain formulation is
activated for an element when
(1) Where,- Element characteristic length,
- Speed of sound into the material
- /DT/AMS applied to selected parts (in /AMS from Starter Input file) does not exclude a joint usage of /DT/NODA/CST applied to non-AMS designated parts of the rest of the model. This is even advised in order to minimize computing time in models where AMS only applies to selected parts. Note that it is pointless to use a higher time step in AMS than the one used in classic mass scaling since the smaller time step limits the performance.
- Airbags without reference metrics should work
