/RBE3
Block Format Keyword Defines the motion of a reference (slave) node as the weighted average of the motions of sets of master nodes.
/RBE3/rbe3_ID
rbe3_title
Node_IDr Trarotref N_set I_modif
For each set with different weighting factors
WTi Trarot_Mi skew_IDi grnd_IDi
rbe3_ID Interpolation constraint element identifier.
(Integer, maximum 10 digits)
rbe3_title Interpolation constraint element title.
Node_IDr Reference (slave) node identifier.
(Integer)
Trarotref Code of DOF used for reference node.
= 0
Free DOF
= 1
Fixed DOF
(6 Booleans)
Default (blank or 6 zeros), set on all DOF
N_set Number of different weighting factor and/or Trarot sets.
(Integer)
I_modif Modification of weighting factor flag. 4
= 1
Modification is automatic.
= 2
Forbidden modification.
3
Change all weighting factor to unity (1.0).
Default (blank or zero), set to 1 (Integer)
WTi Weighing factor of set i.
(Real)
Trarot_Mi Master nodes' code of DOF used in interpolation of set i.
(6 Booleans)
skew_IDi Local skew identifier of set i.
(Integer)
grnd_IDi Node group defining master nodes of set i.
(Integer)
Codes for Translation and Rotation: Trarotref and Trarot_Mi
(1)-1 (1)-2 (1)-3 (1)-4 (1)-5 (1)-6 (1)-7 (1)-8 (1)-9 (1)-10
      TX TY TZ   ωX ωY ωZ
TX Code for translation TX.
= 0
Free DOF
= 1
Fixed DOF
(Boolean)
TY Code for translation TY.
= 0
Free DOF
= 1
Fixed DOF
(Boolean)
TZ Code for translation TZ.
= 0
Free DOF
= 1
Fixed DOF
(Boolean)
ωX Code for rotation ωX .
= 0
Free DOF
= 1
Fixed DOF
(Boolean)
ωY Code for rotation ωY .
= 0
Free DOF
= 1
Fixed DOF
(Boolean)
ωZ Code for rotation ωZ .
= 0
Free DOF
= 1
Fixed DOF
(Boolean)
  1. This is equivalent to OptiStruct's RBE3, in which motion of a slave node depends on the motion of a group of master nodes with weighted average. It is similar to but more general than the kinematic condition interface TYPE2 (which is limited by one slave node to one master segment (3 nodes or 4 nodes) and for all translations and/or all rotation components), the slave rotation is computed as a function of translation and rotation of master nodes, if all DOF are set on in Trarot_Mi.
  2. It is recommended that for most applications only the translation components be used for Trarot_Mi (Spotflag =1 in /INTER/TYPE2). An exception is the case where the master nodes are co-linear and some of the slave rotation components can not be determined. In this case, some rotational component should also be set on.
  3. The absolute values of the weighting factors are not important; it is the relative values from different sets that are important since these will be normalized.
  4. All DOF of the slave node should be determinable.
    If only translation components are used for Trarot_Mi and the master nodes are quasi-collinear, numerical instability might occur in explicit analysis to avoid this; Radioss by default, will modify the input weighting factors slightly (I_modif = 1). To prevent this modification, set I_modif =2.
    I_modif =3 will give an equivalent behavior as /INTER/TYPE2 with Spotflag =1.
  5. It is not recommended to define a hierarchy involving RBE3, with other constraint equation (kinematic conditions; however, this is permitted, if the hierarchy rule has been respected.
  6. Hierarchy rule involving /INTER/TYPE2, /RBE2, /RBE3, and /RBODY is:
    RBODY > RBE3 > RBE2 > INTERFACE TYPE2
