/SHELL
Block Format Keyword Describes input for 4-node shell elements.
/SHELL/part_ID/unit_ID
shell_ID node_ID1 node_ID2 node_ID3 node_ID4   ϕs Thick
part_ID Part identifier of the block
(Integer, maximum 10 digits)
unit_ID Optional unit identifier.
shell_ID Element identifier
(Integer)
node_ID1 Node identifier 1
(Integer)
node_ID2 Node identifier 2
(Integer)
node_ID3 Node identifier 3
(Integer)
node_ID4 Node identifier 4
(Integer)
ϕ s Orthotropy angle to element skew. 5
(Real)
[ deg ]
Thick Shell thickness
By default, this shell has the thickness given in the property set prop_ID of the part part_ID.
(Real)
[ m ]
  1. The identifier must be unique in each element family, but it is advised for each element type to have a unique element identifier in the global model.
  2. More than one shell block can be used to define a part.
  3. Any number of shells can be defined in one block.
  4. For Coordinate system in 3-node shell element, refer to Radioss Coordinate System in the User Guide.
  5. If def_orth = 1, the orthotropy angle, ϕ s is only used in /PLY and /PROP/TYPE19 (PLY).
