Organize Design Points
Besides the Auto DDP option, you can organize your model using the other options available in the context menu.
Duplicate DDP Set
Results in another design point set created with reference to the exact same design points as in the source design point set (same design point IDs, no duplication). Methods assigned to the source design point set are not copied.
Paste
Paste design points that were previously cut or copied from another design point set. This does not result in new design points created, but a reference inside target design point set.
Remove
Removes a reference to a design point from its parent design point set, but does not delete it from the database. However, if the reference count is zero, then design point will be deleted too.
