Smooth Elements
Use the Edit Elements: Smooth tool to optimize the quality of selected elements.
- It is used by an element that was not selected.
- It is selected as an anchor node.
- It is attached to an edge, vertex, or meshing fixed point of a surface.
- It is used by a 1D element (whether or not that element is selected).
- It is not attached to a surface, but is on a feature line of the mesh of the selected plate or shell elements.
Edit Elements: Smooth Tool
An overview of the Edit Elements: Smooth tool.
- Access
- Go to .
Option
- Allow to move fixed and shared nodes
- Allow moving fixed and shared nodes for element operations.
