Datasets
Vehicle Parameters
Parameter | Type | Range | Comments |
Vehicle Mass | Real | Value>0 | |
Final drive ratio | Real | Value>0 | Coupler ratio between drive coupler output and input shafts. Note that drive ratio is 3.7 in case of default RWD model and 1 in case of default FWD model. This value is not parameterized. |
Transmission efficiency | Real | Value>0 | Input omega/(output omega*Drive ratio). |
Drive type | Option | Value = FWD or RWD | Four wheel drive not allowed for advanced driver. |
Max. powertrain torque | Real | Value > 0 | Torque produced by the powertrain at the input shaft of the differential at
100% throttle. *Required only for vehicle models without CSE powertrain. Driver can directly query CSE powertrain. |
Min. Powertrain torque | Real | Torque produced by the powertrain at the input shaft of the differential at
Maximum front braking torque | Real | Value>0 | Maximum braking torque on front axle at 100. |
Maximum rear braking torque | Real | Value>0 | Maximum braking torque on rear axle. |
Brake bias | Real | 0<Value<1 | Front to Rear. 0 is 100% front, 1 is 100% rear. |
Front wheel radius | Real | Value>0 | Loaded radius |
Rear wheel radius | Real | Value>0 | Loaded radius |
Front cornering stiffness | Real | Value>0 | |
Rear cornering stiffness | Real | Value>0 | |
Vehicle a | Real | Value>0 | X component (Vehicle SAE system) of the distance from vehicle front axle to vehicle CG. |
Vehicle b | Real | Value>0 | (Wheel base - vehicle a) |
Vehicle yaw inertia | Real | Value>0 | |
Steer ratio | Real | Value>0 | Ratio of steering wheel input to tire motion (toe). |
Analysis Settings
Altair Driver file | File | Address of the file path |
Signal Dimensions
$Example ADF end conditions block
(END_CONDITIONS)
{SIGNAL GROUP ABS OPERATOR VALUE TOLERANCE WATCH_TIME}
LONG_VEL 0 Y SS 0.0 0.0001 1.50
ROLL_ANGLE 1 Y SS 0.0 0.0001 1.50
PITCH_ANGLE 2 Y SS 0.0 0.0001 1.50
YAW_RATE 3 Y SS 0.0 0.0001 1.50
CG_Z 4 Y SS 0.0 0.0001 1.50
Using this block in ADF and signals dimension dataset, Driver will know the appropriate conversion factors for each and every value.
Control States
MDL Statements | |
gse_advanced_driver | Variable name of the driver cse. |
“CSE Advanced Driver” | Label |
6 | Number of outputs. |
sa_u_advanced_driver | Solver array with input signals. |
Driver resizes the state array and sets initial conditions of the states internally. Hence, the state IC array should not be provided. | |
USER | Indicates that Motionsolve should look outside its dll’s for the entry point. |
USER({sa_par.idstring}) | Function call with par[0] = Array ID with vehicle parameters |
1 | The number of states are by default set to 1. |
Msautoutils | Looks for this dll first in the current directory and then in MotionSolve installation. |
SCRIPT_DRIVER | Entry point function name. |
Motions
Steering wheel motion | Driver computes the required steering angle and applies motion to the steering wheel joint. |
Front and rear wheel motion | Required to lock the wheels during static simulation and lock the wheels. |
Differential motion | Required to lock the differential during static. |
Solver Arrays
Mass Info Array |
Brake Info Array |
Tire Info Array |
Drag Info Array |
Driver Info |
Drive Train Info Array |
*If gear index, i > Number of gears, N Gear Ratio [i] = Gear Ratio[N] |
Bicycle Model Info Array |
Vehicle Parameters Array |
Input Signal Array |
Signal channel
Control Entity Array List of motion ID’s and Joint ID’s passed to driver for deactivation after running static analysis |
Solver Variables
Steer | Driver steer output -ARYVAL ( {driver_output_array_id }, 1 ) |
Throttle | Driver throttle output ARYVAL ( {driver_output_array_id }, 2 |
Brake | Driver brake output ARYVAL ( {driver_output_array_id }, 3 ) |
Gear | Driver gear output ARYVAL ( {driver_output_array_id }, 4 ) |
Clutch | Driver clutch output ARYVAL ( {driver_output_array_id }, 5 ) |
Distance traveled by the vehicle | DIF ( {diff_dis_travel.id} ) |
Longitudinal velocity wrt to gyro | -VX ( <Gyro fixed marker> , <Ground body CM marker> , < Gyro fixed marker > ) |
Lateral velocity wrt gyro | VY ( <Gyro fixed marker> , <Ground body CM marker> , < Gyro fixed marker > ) |
Yaw rate wrt gyro | WZ ( <Gyro fixed marker> , <Ground body CM marker> , < Gyro fixed marker > ) |
Longitudinal acceleration wrt gyro | -ACCX( <Gyro fixed marker> , <Ground body CM marker> , < Gyro fixed marker > ) |
Lateral acceleration wrt gyro | -ACCY( <Gyro fixed marker> , <Ground body CM marker> , < Gyro fixed marker > ) |
Engine speed | Engine speed attachment |
Longitudinal displacement | DX ( <Vehicle Body>) |
Lateral displacement | DY ( <Vehicle Body>) |
Vehicle heading angle | AZ ( <Vehicle Body>) |
Simulation time | TIME |
Roll Angle | AX(<Vehicle Body>) |
Pitch Angle | AY(<Vehicle Body>) |
Roll Rate | WX(<Vehicle Body>, <Ground Body>, <Vehicle Body>) |
Pitch Rate | WY(<Vehicle Body>, <Ground Body>, <Vehicle Body>) |
Template
PLT file is generated at the end of the simulation. |
Writes out states of each and every component in the model. Default = ‘FALSE’ Slows down the simulation speed if switched on. |
CONSUB call to simulate transient and deactivate all the motions and joints after that. |
Sensors
Maneuver switch | Switch to end one maneuver and start next maneuver. Sensor uses a sensor subroutine to monitor the signals and end conditions associated with the signal to actuate the switch. |
