Driver Outputs
Driver Outputs |
Driver Inputs (1) |
Driver Inputs (2) |
*Only in case of manual transmission |
Driver Inputs (3) |
Signal Channel (1) |
Driver Requests general |
Driver Requests – Long Controller |
*Acceleration if type = follow acceleration *Velocity if type = follow velocity **Works only if Longitudinal Controller is closed loop type. |
Driver Requests- Steer Controller |
**Works only if Steering Controller is closed loop type. |
Driver Analysis Components
Typically it is not necessary to edit the analysis components, however advanced use may require editing these properties.
