HTire Additional Plot Signals Output File
The table below lists the channels and their meaning:
Channel # | Unit | Explanation |
1 | mm | tire deflection |
2 | m/s | deflection velocity |
3 | % | wheel slip |
4 | deg | side-slip angle |
5 | deg | camber angle |
6 | deg | wheel rotation angle |
7 | m | traveled distance |
8 | deg | normalized wheel rotation angle |
9 | rad/s | wheel angular speed |
10 | m | traveled distance |
11 | m/s | wheel longitudinal velocity |
12 | m/s | wheel lateral velocity |
13 | m/s | wheel vertical velocity |
14 | % | turn slip |
15 | N | stationary fore-aft force |
16 | N | stationary side force |
17 | Nm | stationary aligning torque |
18 | 1/m | road profile curvature |
19..21 | N | rim forces, expressed in TYDEX C frame |
22..24 | Nm | rim moments, expressed in TYDEX C frame |
25..27 | N | rim forces, expressed in TYDEX H frame |
28..30 | Nm | rim moments, expressed in TYDEX H frame |
31..33 | N | contact forces, expressed in TYDEX W frame |
34..36 | Nm | contact moments, expressed in TYDEX W frame |
37..39 | N | contact forces, expressed in ISO coordinate system |
40..42 | Nm | contact moments, expressed in ISO coordinate system |
