OS-V: 0720 Straight Cantilever Beam
MacNeal-Harder Test This is a straight cantilever beam solved with solid and shell elements. Three models (rectangular, parallelogram,
trapezoidal) are made with each element's type to investigate the effect of distorted elements with a high
aspect ratio.
